Another spark plug thread but little different...
I read on other car forums that by using a hotter spark plug gives a more complete burn. What do you guys think of this?
Right now I'm running BKR5E-11 which is a copper plug. Before I ran the stock plug which was platinum. I'm thinking maybe if I switch to BKR4E-11 maybe I will get an even better burn. I don't even know if they got the 4 series plug. EDIT they do have the BKR4E-11 so what do you think??? SO far I have done to my ignition.... 1) new distributor cap 2) new distributor rotor 3) new spark plugs which are copper 4) new spark plug wires Now the only requirement is that my timing has to stay the same. My stock timing is 20 degrees. Now by switching to one sep hotter what are the pros and cons??? |
A little discussion has been
A little discussion has been about this lately:
https://www.gassavers.org/forum_topic/halo_sparkplugs.html And, the immortal words of MetroMPG: Quote:
I don't go for crap that
I don't go for crap that promotes anything. I don't pay attention to websites that are paid by manufacturers or the government.
I only pay attention to real people with real cars. |
Re: I don't go for crap that
And he's not selling a product. |
He seems to be very
He seems to be very negative. His only solutions are to drive better and get an economical car.
SO does anybody have any pros/cons about using a one step hotter plug? |
hotter
The only reason to go 1 heat range hotter is if they are getting fouled. One heat range is not a big jump. I used to run a hotter plug in front than the back in my v twin MotoMorini motorcycle as the rear plug and cylinder runs a little hotter than the front. Going too hot will cause pre-ignition and knocking at high speed and really damage the engine. So if your plugs are a little brown do it.
The spark plugs are just
The spark plugs are just fine now.
