GPS Problems
Hi I just got Acar pro and using it on Lenovo Android phone, when I try to start a trip using location the little dot spins around then says no signal GPS too weak etc yet when I try google maps app in the same spot it just finds my address exactly in New Zealand, any help would be appreciated.
Thank you |
Sorry you're having trouble!
Is your GPS turned on? Google Maps will try and obtain your location using your IP (either by the Wi-Fi or Mobile Network connection you're using) to guess your location. aCar relies solely on GPS on your device being turned ON. There is also a setting in aCar that turns ON/OFF the location fetching. That specific setting is also available on "Add/Edit Trip Record" screens (from the top right corner overflow menu). |
