You don't need a smaller
You don't need a smaller motor to accomplish your goal. You need a better way to use the fuel. Like fuel cutoff, fuel heaters and engine management.
I've got fuel cut off like
I've got fuel cut off like all the newer hondas and stuff, so that's there. I have engine management also. Fuel heaters don't work according to diamond larry which makes sense to me but meh.
I think the 1.2 versus 1.5 would be a huge difference in mileage. |
Re: I've got fuel cut off like
Sleeving (at least in its
Sleeving (at least in its normal sense) does not affect displacement. The sleeves are the gaps outside of the piston.
https://www.drwtransmission.com/image...%20sleeves.jpg The sleeves would be the junk with the holes which replace the just empty area: https://www.turbomagazine.com/tech/01...ker04_zoom.jpg |
See I told you fuel heaters
See I told you fuel heaters work, it just needs to be adjusted. Megasquirt would at least improve fuel economy by 2mpg. But spending a crap load just to get 2mpg is pointless.
Quote:Megasquirt would at
Re: Quote:Megasquirt would at
w00000t! |
Re: Sleeving (at least in its
https://www.brafilm.no/movie_images/h_304112.jpg |
I suck. I think I was
I suck. I think I was confused by the DIY sleeving article that's on honda-tech. Seems more like a DIY block guard I guess, :(
