Inconsistent Octane Values
In my area, the mid-grade octane is 88. So that's the value I've kept in GasCubby. However, when I'm in another area fairly close to me, the mid-grade octane is 89. If I change GasCubby's mid-grade value to 89, then all of my mid-grade entries also change to 89, which I consider a bug.
Will v3 allow numeric octane values, as well as convenient default low/mid/high settings? |
This is an interesting point.
I'll bring it up in our next meeting and find out what we plan to do going forward. |
Going forward we will allow for Octane levels to be set per fuel-up.
So changing the octane rating will not retroactively change any of your other records. There will be a Default setting on a vehicle level, for convenience, but there's still the option to edit each fillup if necessary (like in the situation you described). |
