Can someone give me the abridged version...
So whats the deal with hydrogen injection?? I wouldn't imagine the small amount of hydrogen you can produce would greatly effect the combustion process. Maybe I'm wrong...
Long Story Short
Long story short, the Hydrogen Injection:
* Is very dangerous to control the reaction * Hasn't proven to gain a lot of MPG's * Has by-products that could eat away the engine's vital components, pretty quickly I've kinda given up on it... RH77 |
Re: Long Story Short
My brother said he saw something on the news where he lives about Hydrogen Injection, but I've also seen news reports for the hologram sticker that you put on your gas tank and it increases the gas mileage by 20%. |
Talked to a chemist, it
Talked to a chemist, it won't eat away the aluminum. Also too much maintenance and if you build an electrical one you will need some good electrodes, none of that home depot crap. Stainless steel is suppose to be really good. I got a large chunk of stainless steel from my uncle. All I have to do is just put the genearator together. I'm leaving it as a last chance thing. I got too much stuff to experiment before I put it on.
Quote:Actually, I'm unsure
I think diamondlarry loves h2, and his buddy fran giroux made like 109 mpg on it with a saturn. |
Re: Quote:Actually, I'm unsure
Like I said, it hasn't been "proven," per se. I'm awaiting an actual scientific experiment, with controlled conditions. It would actually be pretty cool to do a controlled experiment with this, as a blind study. Get three people to agree to let you make a few modifications to their car. Tell them you are going to install a computer or something that tracks engine conditions and that you need to leave it on for one tank. Do not let them know when you install it however, or which tank it is installed on. Do this with 5 different people on 5 different cars and you should get a good idea if there is a significant increase in MPG or not. If I had a working unit I would do this. |
The current units require
The current units require too much maintenance. I'm not comfortable of running the hydrogen generator while driving. The best bet would be to get the A/f ratio really flat.
If you want a lot of hydrogen you got to waste a lot of amps. Japanese are now starting to build cars that don't run accesories on the motor. Power steering, air conditioner, brakes, cams and etc. It gives a good boost in mpg. |
Re: The current units require
Matt,
I'm a chemical
Matt,
I'm a chemical engineer and I am currently experimenting with a H2 generator, conducting controlled lab experiments with it. I installed it in my 1998 Ford Ranger this evening and I am moving into "phase II" to see if it does anything for my MPG. Unfortunatley, I can't afford a dyno for true controlled tests of the truck and will have to settle for real driving, with lots of data collection. Right now, I am pessimistic about what type of results I will realize, but I'll just have to wait and see. |
Re: Matt,
It would be best if you posted your results in the Experiment section of this forum. Simply create a new post detailing what you are doing and add results as you get them. It will be nice to have another person working with Hydrogen Generation. If you don't mind, please start a thread here (in the h2 section) about your setup and what it is you are using. |
