my engine swap is on the horizon (a month maybe? As soon as it quits randomly snowing here) I figured I could try a few things to determine if they help with gas mileage.
The main thing I wanted to try was to relocate the o2 sensor by switching t
Considering my engine swap is on the horizon (a month maybe? As soon as it quits randomly snowing here) I figured I could try a few things to determine if they help with gas mileage.
The main thing I wanted to try was to relocate the o2 sensor by switching to a different exhaust manifold. In theory an o2 sensor that is closer will react better and help adjust AFR quickly. I already have the exhaust manifold, so I went to the junkyard in hopes of getting a different catalytic converter as well as a shorter downpipe. in theory they should all fit. Well, apparently there is some silly federal law that says you can't sell used catalytic converters. Who knew?!?! I don't want to try to much more on this project, so unfortunately i won't be able to do it. Unfortunately modifications take money. I may, however, be interesting in helping someone else do the same experiment. Just wanted to return and report. |
wouldn't it be better to
wouldn't it be better to have the o2 sensor closer but that is a wideband. I think the best results would be a closer o2 that is a wideband instead a closer one that is a narrowband.
Which sensor will be done? |
Re: wouldn't it be better to
If I wanted to utilize a wideband i would have to have the appropriate ECU and it would involve a bit of wiring. In theory even a narrowband that is closer SHOULD react faster which would yield an improvement in mpg. The best way to do an experiment is to only change ONE THING and test for changes. |
Yes, there is technically no
Yes, there is technically no honda ecu prior to 2001 besides the xv and hx that won't get pissed at you for using a wide band, they don't know how to interpret it, anything over 3.7 volts gets thrown out and anything over .8-1 volt is uninterpretable. I'll have to see if I can get myself I vx cat, what other parts were you thinking you need besides the manifold?
Re: Yes, there is technically no
I may have the exhaust parts
I may have the exhaust parts for you, I'll know later if my friend wants to sell them.
I'm yelling at you on AIM,
I'm yelling at you on AIM, but you just went idle, y0. I picked up a cx exhaust today for free from manifold to downpipe, you can have what you need besides the manifold because I'll prolly try and sell that and you have like three of them, :p. It has the cat and an extra 1 wire with plug if it pleases you to use that.
Another free part?? ROFL
You
You don't steal them by any chance? lol |
Re: I'm yelling at you on AIM,
I'd love a free cat and downpipe. I might be able to use my existing exhaust now and just replace my existing cat with a test pipe... or just run two cats. Anyway, I'll chat w/you about it tomorrow. |
Quote:Another free part??
