What is partially fuel up and Missed fuel up?
Hi guys! could someone explain me what the partially fuel up option is and the missed fuel up one?
I don't do my tank full, so have I to choose always the partially fuel up option when I add a fuel up? |
Fuelly can only calculate your economy if you go from full, to empty, and then full again. You cannot calculate your economy unless you do this, every fuel up will be partial the way you do it.
A missed fuel up is if you are tracking via odometer reading only. |
Looking at your figures I think you may have added most of your fuel ups incorrect, some are as low as 26 MPG, and other are 70 MPG, that's a huge difference.
Thanks for your reply |
You don't necessarily HAVE to go to empty. That's just ideal.
You just need to fill your tank (top it off) with every visit to the pump. Even if you fillup when your gauge reads half-tank, as long as you pump until it's full (usually when the nozzle clicks/stops) then you're all set. A partial fillup is if you only put in say "$5 worth" regardless of the amount of fuel you actually pumped. So if you're at half a tank, visit the fuel station and only pump enough fuel to get you to the 3/4 line, then you have NOT filled-up, and must mark it as a Partial Fill. |
This same issue comes up time and time again on fuelly. I've pointed out numerous times that in many parts of the World, high fuel prices mean most people rarely fill thier tanks ever. It's a great programme for some people, but doesn't suit everyone! :)
Thanks a lot for your replies. I'll try to use the software in the correct way
