Missing MPG/miles travelled
I'm sure this is really simple, but I can't work it out- I added a fuel up, and it has not calculated the miles travelled or MPG values for that tank. I have NOT ticked the partial fuel-up option, and both the last preceding two fuel-ups calculated things correctly, and were not partials. What else could it be?
Looking at your log, it looks like you forgot to put the miles in, only litres? Try editing the fuel up and make sure all fields are full.
Looks like you entered an odometer of: 481,070
Your previous fuel up has an odometer of: 47,679 That's like 49k MPG US I think. Haha! Fuelly assumes this is an error and went ahead and ignored it until you make the correction. Simply edit and fix your odometer entry and MPG will be calculated upon save. |
I'm an idiot :-) Thanks.
I am having this same problem with my Volt, except my entry is not an error. Last time I bought gas I had 3262 on the odometer, and today when I filled up I had 9399 on the odo. How can I force fuelly to do the calculation?
Fuelly is not yet set up to support Electricity use. So MPGe figures are not available, therefore 6,000 miles on a tank of fuel alone is unrealistic. |
