Import ACar Data Into Gas Cubby
Is there anyway to import Acar data into Gas Buddy? I'm a pro user on both. I don't mind exporting to CSV and then importing if that works.
Gas Cubby does not currently have an import function.
If you can hang tight a little longer, both will have sync to Fuelly which will achieve your intended result. |
As for a specific formula... that's above my understanding... so I'll have to get back to you on that. |
I am in the same boat, prior ACAR user with lots of data history, switched to iOS/Gas Cubby and would like to get the Data Over!
If you can pull a backup of the SQLLITE database from Gas Cubby, and have an export from aCar you can marry the data together, just takes some trial and error.
