When to Fill up at the station to get the best value.
The Theory is simple. To get the BEST value at the gas station when you are filling up your gas tank is to either fill up in the EARLY morning or to Fill up LATE at night when the Air and ground is cool and the tanks under the station are in a settled state. Is this True? or another line of BS? Where I live it's hard actually test due to the price of gasoline fluctuating so frequently. I paid $2.49/gal this morning for Mid-Grade. By the time I go past the same station again tonight the price I'm sure will have changed to something higher or lower. Just from the station to my house which is approx 16 miles on the otherside of the town price was $2.69/gal at same name station for same grade. Is there a way to acutally test this theory? I'm guessing record the amount of fuel that is actually pumped if i can get there when the fuel happens to be the same price?
Someone on here way back
Someone on here way back when validated this...it can't hurt I say.
Also, I think MetroMPG has mentioned his gas pumps are volume corrected for temperature. |
Well at least it's saving a penny
Cool cool, thanks for the response... and at least now everyone knows that Hey It's worth keeping in the back of your mind when your out looking for gas between 11pm-5am.... yes all you party goers that forget to get gas BEFORE you go out... lol Thanks again SVOboy...
underground tanks
AHHHHHHHH The whole point of underground tanks is stable temeratures so I don't think you will be seeing any big change in the density of fuel between morning and night. Maybe better to gas up just after the tanks are filled or just before they are empty - fresh (cold tanker truck) gas or less volatile components (already evaporated off in the tank).
There has none the less got
There has none the less got to be a slight difference.
Re: There has none the less got
Temps
If you knew how much gasoline expands and contracts per degree you would realize how little we are talking about unless there is a big temperature difference. Now if you wanted to check the fuel pump then get a 5 gallon ridged fuel container that you fill at various pumps and see which one reads the least amount of fuel pumped. I recommend a 5 gallon container because that is the size they use to test the calibration of the pumps and stations that "play" with the pump calibration usually pump less below and above 5 gallons to cheat you of the fuel.
I have been told to refuel
I have been told to refuel at night. I rarely do that.
here in canada, volume is
here in canada, volume is corrected to 2 degrees C i think or 23 which ever one sounded more reasonable.
refuel
I just got a full tank today and they had the truck deliver this morning and they had not raised the price yet PHEW got lucky ! Usually I get gas on Sunday and the truck seems to come on Monday so I got fresh gas this time - will see if it affects the mileage. I think I will get gas on Sunday to get the better price - paid $2.459 today but I already see local prices at $2.699 for Reg $2.899 for Prem looks like $3 a gallon is not far away - say a 10 to 24 cent price difference from Newport to Tiverton where I gas up.
