SOLVED: CSV import - page not found
1 Attachment(s)
I just tired to import a csv and get the attached error (page not found). Does it show this if the format is screwed up? :confused: Please help.
Well, yes that is what it shows if you have an invalid column. I was trying to import the "brand" since this is a column in the export but it didn't like it. I removed the "brand" column and it worked.
Suggest adding a column for all input fields you can add when clicking "Add a fuel-up" e.g. Fuel Rating, Fuel Brand, etc. |
I don't think I've ever experienced that error page. Usually it just takes you back to the import screen with red text explaining the error.
Can you send me your CSV (the original one)? |
original csv
1 Attachment(s)
@RobertV
Here is my original csv. I removed the "brand" column and the import worked. |
