Gas and diesel data
Hello,
I am researching a 2011 Mercedes Benz E350 4-matic gas engine. When I went to look up that particular vehicle all the data had blue-etc (diesel) engines combined/intermingled with gas engine data. The published data is no use for fuel economy if the system doesn't break out the different fuels. Then I checked Audi and found the same thing. Bad data is worse than no data at all. Thanks, Tom |
There is a filter where you can select the engine/fuel type. By clicking a particular model, you should be able to see this option at the top of the page in form of a small drop down menu.
Thanks for the info, I will look for the filter.
