-   iOS | Fuelly Mobile (https://www.fuelly.com/forums/f41/)
-   -   Any way to merge logs? (https://www.fuelly.com/forums/f41/any-way-to-merge-logs-18961.html)
mr3wan 09-26-2016 05:22 PM
Hey Guys,
I have 2 separate entries for my car due to some confusion. Both of the entries have a large number of logs. Is there any way to merge to 2 'vehicle's' logs into one entry.
example
Car A 1
Has logs 2010-2015
Car A 2
Has Logs 2015-2016
Can these be merged into
Car A
Logs 2010-2016?
RobertV 09-28-2016 12:18 PM
I'm assuming you mean your Outback?
You can Export the fuel up records from this vehicle: Subaru Outback XT (Subaru Outback) | Fuelly
and then import them into this one: Subaru Outback 2.5XT (Subaru Outback) | Fuelly
Only fuel-ups will export/import currently (limitation on the website at the moment).
Which is why I recommend exporting the vehicle with only 92 records. Shouldn't be too many service records (~8) that you'd have to reenter manually.
Once you've completed the export/import process, you can then safely Edit->Delete the first vehicle (with the 92 records).
Here's how to Export: FAQ: How do I export my fuel-up data?
Here's how to Import: FAQ: How do I import fuel-up data?
There will not be any need to edit the export file in anyway, so as soon as you've exported/saved it to your desktop, then view the receiving vehicle and tap import and upload the csv you just put on your desktop. It should be a relatively smooth process.
Let me know if you have any questions/concerns!
mr3wan 09-28-2016 02:03 PM
Hey RobertV
Thanks abunch for the quick reply. I will give it a shot and see if I can get that to work for me!
