Danny, ever figure out what you got from the thermostat?
I finally figured out that big piece of **** on the block was the thermostat housing, so w00t w00t, time to pop mine's ins.
Have you gotten data on yours or did that problem screw you? |
Re: Danny, ever figure out what you got from the thermostat?
Damnation!
Damnation!
Just put in a 195 thermostat
Just put in a 195 thermostat and be done with it.
That's the plan, it's
That's the plan, it's sitting in a box in the garage, will be in tomorrow.
Before installing the new
Before installing the new one I put both new and old in a small pot of water and warmed them up on the stove. For sure the 172F was wide open before the 192F even moved. Seeing is believing.
Did you drain your coolant
Did you drain your coolant when you did this? How much did you end up loosing?
No I didnt drain the
No I didnt drain the coolant. Just pulled the radiator hose off and arranged it so the opening was sticking upward so no more would leak out. At most i lost 1 qt. I just added water.
Haha, that's prolly what
Haha, that's prolly what I'll do then. I gotta go to honda and buy some washers since I'm paranoid anyway, might as well just spill all my coolant, :p
i guess i'm an anomoly. I
i guess i'm an anomoly. I dropped in a 180 thermo some time ago shortly after i moved into a hilly area.
Actually, i was having starting problems on hot days when the engine was warmed up all the way. That went away almost completely with the lower thermo. The most important part, no mileage change while i was watching it very closely. My best mileage run wich was just under 25mpgs in my truck was done with the 180.... Of course, i'm in a truck, a 1991, and a TBI, so maybee for all you nicely tuned guys, this post was for nothing. |
