Gas Cubby Fuelup form - big problems since one of the last updates
Hi Fuelly support,
since one of the last Gas Cubby updates I have a big problem with entering new "Fuelups": 1) Previously it was ok to only enter Cost/L + Litres. The Total Cost field was calculated automatically. This doesn't work any longer. 2) Although I enter the correct values, the result is completely messed up and Fuelly tells me it can't sync this entry to server. Here are some screenshots which shows the problem: https://dl.dropboxusercontent.com/u/...6/IMG_0076.PNG https://dl.dropboxusercontent.com/u/...6/IMG_0077.PNG https://dl.dropboxusercontent.com/u/...6/IMG_0078.PNG https://dl.dropboxusercontent.com/u/...6/IMG_0079.PNG I already did the following to solve the problem (but didn't help): 1) completely uninstalled and reinstalled Gas Cubby (now I have installed the latest version from 2016-11-13, Version: 3.0.15, Build: 3.0.15.3) 2) resynced all vehicles 3) tried to enter the Fuelup many times in different oder 4) restarted the iPhone Here is my setup: I'm using an iPhone 7 Plus with 256 GB. The device language setting is "German" The region setting is "Austria" (we have the comma (,) as floating point separator) The Units setting in Gas Cubby is Litres/100Km. Could you please have a look at this? Thanks in advance, Martin |
I'm seeing the exact same thing with version 3.0.15 on iOS. It seems to be related to decimals; as its not allowing me to hit ',' when I enter the values for liters of fuel and cost. If I copy-paste a '.' its allowing me to enter the numbers normally, but it doesent save correctly, so its impossible to enter correct values. Would be great if this could be adressed and patched asap :)
Yes, our last update created this issue. The developer has found the cause and is working to correct this issue. We hope to release the update soon.
We apologize for the inconvenience. |
The update to correct the problem is now hitting the app store. If your app doesn't automatically update, please check the app store.
