Speculate II: What kinda smack will a vacuum leak put on FE?
Yeah, figured it out finally! Thanks again jared, :). There's something wrong with the pcv line, prolly gonna just replace the whole damn thing tomorrow if I can't figure out how to fix it. Anyway, it leaks enough to keep the engine idling at 4-500 with no other air coming in, any idea how much this has been hurting me?
Well, no one speculated but
Well, no one speculated but I got it fixed, I had a bad pcv valve, the car is peaches now, however.
glad to hear its running
glad to hear its running well :)
Except for the surge during
Except for the surge during warmup! It's pretty small really, like 200 rpms, slower also, and lets not forget, it seems to idle high then, but I forget what is normal, to be honest.
you can adjust your ect idle
you can adjust your ect idle curve in crome
though i dont recommend much... you'll see the biggest change at the lowest temp during startup naturally... you could lower that a little |
That's the plan, I did it on
That's the plan, I did it on dan's car as per request, wasn't planning on doing it on my own, but I might have to.
now mess with the idle
now mess with the idle screw?
I will next time I feel like
I will next time I feel like ****ing with the car. But yeah, that's the next plan of action.
