Hi Everyone
Just a quick hello to everyone.One question though,why is it that despite putting in the fuel costs it always reverts to £1.39 per litre?.I drive a BMW M240i which is achieving a reasonable 30mpg.However,due to the wrong price of the fuel it is saying it's doing over 40mpg!.
Wouldn't that be great |
Hey welcome. I had a similar issue before, cant remember how it was resolved, i'm sure one of the team will help you out. Meanwhile, check your settings are UK and you're tracking using litres, UK MPG etc.
I checked your fuel ups, fuelly is correct in its calculations, are you sure you inputted the data correctly as 356 miles over 8.7 gallons is about 40 MPG.
I checked the data and it appears correct.I am running it in atm and most of the use has been on a run at lowish speeds.
Not quite as good as my f30 330d but very impressed nonetheless. |
It is pretty good if correct, although I'd be suspicious, especially as the price jumped. Next time you enter a fuel up, keep an eye on the "price per litre" and "total litres used" if both of these are inputted correctly, you should see the "total cost of fuel up" match that you paid at the pumps. I check that now, as if you try and correct one, the other can jump too.
