100 degrees
1 Attachment(s)
:eek::eek:, I'm getting to old for this carp.
Well, on the bright side, at least your car engine warms up faster to give you better MPG, R.I.D.E.!
I had to slog through that today pulling a gross weight of 76,500lb. My cooling system was nonplussed but did the job. Right around the VA/WV line, I was starting to pick up enough heat that I thought I might have to pull over - the fan on/off cycling wasn't keeping up, but it started to level off. AC was a champ though, my vent thermometer never climbed more than 5*.
On the downside, I got just north of 5.5mpg from Nitro, WV, to Raphine, Va, a 220 mile trip which took 4 hours almost on the dot. |
I loves da hot weather. When it's hot, I dream about below zero weather. Then in the below zero, I dream about the 100+ weather. It's all wonderful. I cook, so I can freeze, so I can cook again. Life's wonderful.
I'm with 14 on this one - its usually too hot cold wet or windy - just depends on how you look at it :)
