Do I need to replace this seal?
I was replacing my throwout bearing today and I noticed that a rubber seal on my transmission looks a little eaten up. here is a picture:
https://images6.theimagehosting.com/seal.th.jpg Hopefully the picture is okay enough for you to see the damage. I believe this is where the axles attach to the transmission. Should I replace this seal, or is ti good? Should I just replace it because it's cheap and easy to do? BTW, replacing the throwout bearing was probably the easiest thing I've done on my car so far. |
That seal keeps crap from
That seal keeps crap from the outside getting in, so long as it hasn't shrunk (and I can't see why it would have) don't replace it. On the other hand, if you plan on keeping that tranny for another 8 years or 150,000 miles I'd get new ones.
Just make sure there aren't any rough spots or rusty spots on your axles when you pop them in there. Use 600grit sandpaper to remove any of those spots if they exist. Then put some light oil on the shaft that will contact that seal, unless you go with new seals, then leave the shaft dry so the seal has a chance to break-in properly. |
A guy on honda-tech says to
A guy on honda-tech says to replace it while it's out so I have one less thing to worry about.
Heh... these two seals and the throwout bearing will end up costing more than the transmission did (excluding shipping, of course). Honda transmission experts: Is this one seal, or two? I'm thinking it's #10 on this picture: https://estore.honda.com/images/parts.../SH23M0200.png Honda.com says: OIL SEAL (35X62X8) Part Number# 91206-PL3-A01 |
Just realized there are two
Just realized there are two oil seals... I need to go check the transmission now... here is the other one:
https://estore.honda.com/images/parts.../SH23M0100.png It's part # 18 OIL SEAL (35X56X8) Part Number# 91205-PL3-A01 Should I just get both of them? |
if you want to replace both
if you want to replace both then buy both...
#18 is the driver side = the one in your picture |
Yep, one seal for each axle.
Yep, one seal for each axle. Personally, I'd replace them both while the tranny is out, but it isn't terrible to replace with the tranny in, other than re-pulling the axles.
You could replace them now, or you could chance it and not have to replace them or you'll have to replace them while in the car. If you have a bad axle laying around, you can cut off part of the part that sticks into the tranny with the splines and use it as an axle seal driver. I have one and have used it a few times. |
There's nothing worse than a
There's nothing worse than a blown seal, said the Eskimo.
Re: There's nothing worse than a
(I am assuming Sludgy told it incorrectly on purpose...) =) |
blown seals suck, doesn't
blown seals suck, doesn't matter what part they are on.
Re: blown seals suck, doesn't
sorry...it was just begging there... |
