Heated fuel lines revisited
I did a search and notice that heated fuel lines has been discussed on this site but couldn't tell if anyone try it. When I looked in the top 10 only one mentioned having heated fuel lines. I saw over a 3% increase in FE when I installed them. Is anyone using them or is my gain unusuall?
What's your setup and all
What's your setup and all that? Is this scangauge verified or just tank to tank?
I'm running 3/8" copper
I'm running 3/8" copper tubing along the top of the radiator hose wrapped with aluminum foil. Water temperature runs between 190-205. Yes it was runs with the scangauge.
Not bad, I'll have to add
Not bad, I'll have to add this to my testing list for when the superMID shows up. Got any pictures?
No, I don't have the
No, I don't have the technology for that yet. Soon though.
can you describe how you ran
can you describe how you ran your test? do you still have the data? it may be worth writing up an experiment summary. i'd be interested to know the details.
Here’s the data taken from
Here’s the data taken from the Scan Gauge. I did 3 runs on my usual 41 mile test loop. It was an A-B-A run. Temps mid 60’s winds south at 10-15 warm engine.
Without the heated lines MPH Avg 40 Gal Used 1.1 MPG 34.2 With heated fuel lines MPH Avg 40 Gal Used 1.1 MPG 35.4 Without the heated lines MPH Avg 39 Gal Used 1.1 MPG 34.4 |
this proves they work
Re: this proves they work
