-   -   My radiator fan is on like crazy (https://www.fuelly.com/forums/f8/my-radiator-fan-is-on-like-crazy-2013.html)
GasSavers_DaX 04-27-2006 03:25 PM
Re: When I went to the grill
Originally Posted by diamondlarry
On some cars,my Saturn for example, the coolant temp sensor doubles as the gauge sending unit. If this were true I would think the gauge would be a little goofy too.
Not the case for Hondas.
rh77 04-27-2006 03:36 PM
Re: I'm going to nitpick the
Originally Posted by SVOboy
I'm going to nitpick the hell out of this. I've also got a damn cel for vss and o2 sensor heater on, but the o2 sensor heater is disabled and the vss is fine. It only comes on after like 20 minutes of driving. :(
I assume VSS is vehicle speed sensor? Maybe it's interpreting that your sitting idling at a low speed and kicking the fans on to get air moving. Why is the O2 sensor heater disabled -- doesn't that, well, help it work properly?
RH77
SVOboy 04-27-2006 03:50 PM
The vss is working just
The vss is working just fine. I don't idle as all during my trip except at the very end after the cel is on.
I have no heater, so if I leave it enabled then the car will run like *** wanting the heater.
