163. You go looking under your brothers cars dashboard to find the obd-2 connector to plug your scangauge in to check his cars fuel mileage.
164. Your last fillup is 25% over EPA estimate, and this causes you to worry about "What is broken in the car, to cause you to get FE that low?".... BTW: Guilty as charged. My current theory is that my brakes may be sticking slightly (it feels a little like that, and the car is 15 years old now). If I'm correct, the extra (partial) brake drag is lowering my FE some, which logically means it's time to look into a brake job... |
165: You park and go inside Wendys, even though theres one car in the drive through and a ton of people inside waiting in line.
166: You haven't exceeded 3500 rpms in about two months, so you floor it in first gear for the hell of it, and the acceleration feels like a corvette. You then look down at the gas gauge to see if the needle fell at all.
167. You shuffle your car around by pushing it to a spot where the engine will be heated by the sun several hours before driving.
168: You put on your running shoes and athletic shorts, and go out and cut the grass in 17 minutes when it should take a half hour.
169. You get the front-end alignment not so much to keep the tires from wearing funny but, so it will cut down on the drag that is killing your FE. 170. You can't enjoy watching 2 Fast 2 Furious with your kid because all those engines whining at such high rpm's much be sucking gas like a fish sucks water. |
171. You get really mad because someone dosen't use there turn signal to make a left turn and you had to touch the brakes.
172. You know that you need to leave half mile buffer zone for the next time that might happen. |
173. when you go to macdonalds, you ride the starter at least 5 times before even taking your order! Since you already banked away money to replace it if it fails! |
