137. You know your a fuel economy freak when you are helping to log and keep track of characteristic's of fellow freak's.
138. You look look forward to roads with 45MPH and 35MPH speed limits since it allows you to "legally" travel at a nice fuel efficient speed without the "peer" pressure from other drivers to at least drive at the speed limit.
139. You curse when you look in your rear view mirror and see another car coming up behind you on a two lane road without a passing zone. |
The seats are stiff, the car is stiff, and so is the tranny. The only thing the altima was better was at handling, i swear. Surprising as it sounds. |
140. You are willing to draft behind a garbage truck despite the stench.
Got this one one my way to work this morning :). |
141 You spend $32K for a diesel truck that gets an incredible 19 mpg highway. <slaps forehead>
142. You buy a Scangauge or SMID
144. You learn not to care about 143 because you would rather have that guy in front of you than behind, and are relieved that he at least has the courtesy to find an alternative to tailgating. |
145. To prevent the cursing caused by 139 you tear off your rearview mirror.:p 145a. You also do this to reduce aero-drag. |
146. (Corollary to several points since 139...) A highway trip becomes notable when you overtake other vehicles along the way. This happened to me on the weekend ... they were driving too slow! Imagine.
147a) You pass someone in neutral with the engine off... going 150+ km/h (they were probably going 120). Down a mountain pass. 4-lanes. Crazy, yes, I know. (Not the Blackfly - it was in my 89 Accord.) |
154 your starter is only used on a hot engine when possible ;D
155 you use your left leg to push 1 or 2 mph back, while your right foot is clutch starting the car. since if i try to move the car with my left leg and then use my left leg to clutch in while from N to R then i will grind the reverse gear (yes even when going backwards!) so I must hold the clutch with my right foot in R before attempting to move the car with my left foot. now i can sneak out without waking anybody up (no cranking). |
156. You go somewhere on an errand that's just far enough to barely get the car warmed up. Then you're unexpectedly delayed while out of the car errand-ing, and you find yourself fretting over the fact that the car is cooling down too much while you're waiting, and you're going to have to take the cold-drivetrain FE hit all over again!
157. Instead of cursing and flipping off the idiotic truck driver who just pulled in front of you, causing you to slow down even though youre only going the speed limit and there is more than one lane, you proceed to draft him, and wave to him when you get the chance. |
158. you ride your bike 2 mile to the store for some icyhot. peddeling with one leg cause other knee is too sore to help out. knowing that you pass by the store on the home, but it's a left turn out in middle of the day.
159. You run 4 stopsigns during a FAS bacause they would kill your momentum.
160. You have thought of ways to make a cars antenna more Aerodynamic. 161. You are happy when it is rush hour because the flow of traffic is 45mph not 70mph. |
162. You're almost disappointed - or wait, maybe you are disappointed - when gas prices fall...
163. You go looking under your brothers cars dashboard to find the obd-2 connector to plug your scangauge in to check his cars fuel mileage.
164. Your last fillup is 25% over EPA estimate, and this causes you to worry about "What is broken in the car, to cause you to get FE that low?".... BTW: Guilty as charged. My current theory is that my brakes may be sticking slightly (it feels a little like that, and the car is 15 years old now). If I'm correct, the extra (partial) brake drag is lowering my FE some, which logically means it's time to look into a brake job... |
165: You park and go inside Wendys, even though theres one car in the drive through and a ton of people inside waiting in line.
166: You haven't exceeded 3500 rpms in about two months, so you floor it in first gear for the hell of it, and the acceleration feels like a corvette. You then look down at the gas gauge to see if the needle fell at all.
167. You shuffle your car around by pushing it to a spot where the engine will be heated by the sun several hours before driving.
168: You put on your running shoes and athletic shorts, and go out and cut the grass in 17 minutes when it should take a half hour.
169. You get the front-end alignment not so much to keep the tires from wearing funny but, so it will cut down on the drag that is killing your FE. 170. You can't enjoy watching 2 Fast 2 Furious with your kid because all those engines whining at such high rpm's much be sucking gas like a fish sucks water. |
171. You get really mad because someone dosen't use there turn signal to make a left turn and you had to touch the brakes.
172. You know that you need to leave half mile buffer zone for the next time that might happen. |
173. when you go to macdonalds, you ride the starter at least 5 times before even taking your order! Since you already banked away money to replace it if it fails! |
I just reviewed my bill and here is the breakdown: 4 tires@ $85 dollars each mount, balance, valves 4@ $13 each replacement tire fee-House act #142 4@ $.25 each tire disposal 4@ $2 each 4 wheel alignment 1@ $59.99 Total: $460.99 + 6% tax = $484.51 |
Me: "I need some BFGoodrich Traction T/A H" (I know they were being sold for around $61 per tire) Him: "how many you need?" Me: "2" Him: "It's going to be $160" Me: "how many times I hooked you up with some customers??" Him: "$150 and they are in stock" Me: That includes taxes, installation, and all the fees, RIGHT?????? Him: "yes" Me: "cool, I'll be there tommorow morning" |
I've been driving in crazy low rpm the whole past month that I was like: "who the hell would build a car with so much needless power?!" (btw, my car has 55 HP) 174. When you are slowly merging on the onramp to get onto the freeway, a truck pins the gas and passes you on the shoulder and cuts you off... only to have him 4 cars ahead when you exit the freeway. 175. You haven't used your horn in months because you know you'll just lose anyway. |
176. A pick up truck is tailgating you and you see that he goes around you to pass but there is not enough space inbetween the cars. So you keep downshifting till you make sure there is absolutly no way he'll pass you. Then you cringe as the fuel gauge is falling.
I was going 65mph:rolleyes: 177. You get such an economical car that you actually start to drive more. So the gas bill stays the same between your gas guzzler and your economical replacement car. |
To: Compac888 Your post is immeasurably better than the lame jokes that folks like to email you every day.
Sad (grin) but true. 179. You can't take your wife with you because she weighs 85#. 180. You can't take your cat anywhere because she weighs 9#. 181. You tell your wife to drive your gas-guzzling pickup today to keep her out of the car. 182. You're thinking of lightweight underwear, WAIT no underwear. 183. You ask the shoe salesman if he has a scale. |
An ICE is an air pump!
Why not just turn off the engine? No RPMs = no fuel flow! :cool: |
haha... read my post from a couple days ago regarding my 'ghetto windows project" |
I am so guilty of # 148... Is there a compiled list somewhere? Or did I just volunteer to make one and host it?
