Adding a reminder
Trying to add a tire rotation reminder but can't enter mileage only does time? Am I missing something?
In the New Reminder screen, near the bottom you will find the Reminder Frequency field. It defaults to Based on Dates, you can change this field to Based on Distance, Based on Dates, Based on Distance or Date.
Nope. it only allows me to select time.
Is your vehicle tracked by Trip Distance? Then, the only option is time. The distance reminders use the odometer reading, they do not sum the fuelups/services.
OK. Thank you. How do I change that?
Tap Edit Vehicle and select Odometer Tracking instead of Trip Distance.
