-   Introduce Yourself - New member Welcome (http://www.fuelly.com/forums/f6/)
-   -   Greetings from Ohio (http://www.fuelly.com/forums/f6/greetings-from-ohio-20446.html)
DonKook 02-26-2019 06:35 PM
Greetings from Ohio
Hello from Ohio,
I have had the Android aCar PRO application for a few years, but I have never really used it in the way it was intended.
for LONG trips (a week or more) I have needed to use several apps for fuel & expense entries, trip tracking, odometer entries, etc., while traveling in the car.
I was hoping that you could go into a "trip mode" that you could lock-into so every entry would be associated with that trip (ex: "Trip to NYC") and when you finish the trip, you can go back to the 'normal' mode. Then you could view or export all the records fro that trip.
I asked the aCar dev for some tips, and I was told to just put the trip name into one of the fields, but the field didn't exist! Well, I think it did, but when I viewed the records, I could not locate the field or sort/filter them by that field.
I'd like to ask for tips on how to simplify entries that you make during a trip, or can I contact the devs to add "trip mode" to the application?
Thanks.
