Rear Wheel Skirts That Bulge (issue)
I'll have to get pictures later, but the problem is pretty simple: my rear wheels are out far enough that I can't make a rear skirt that runs flush with the body of the car.
So, I see that I have two options: 1. Make one that doesn't go all the way down 2. Make one that bulges out a little bit and goes all the way down. Whatcha think? I'll snap some good picture later in the day hopefully. |
800 ? 800: true);
Ah yes... the bulge issue.
I
I think both solutions are good ones for this problem. I've actually considered doing both at one time or another. I'll probably end up making one that goes all of the way down and just bulges out past the tires for the ultra geek effect. |
I think you'll need to go
I think you'll need to go all the way down for increase FE. I have the same problem and tried skirts that came down to the bulge and saw no effect on the FE.:( My driving is mixed, hardly ever get over 60 and most of the time it's around 30-40 MPH averaging about 30-35 MPH for a tank of gas.
down
The bottom of the tire is not moving through the air - ground speed is 0 so you don't have to cover it. The upper half of the tire is moving at twice the ground speed and needs to be covered.
Re: down
Re: down
you still have 0 |
Re: Rear Wheel Skirts That Bulge (issue)
mine bulge out a bit - see the photo in my DIY of the aluminum strip i attached to the back side of the skirt to get an idea of the shape i had to use. you could cheat and stick a set of rear mudflaps on - that's what my skirts attach to (which reduces the amount of "bulge" required to clear the tire). |
Quote:I also see some camber
Quote:i think the full ones
