Re: Sweet - more analytical
Re: Thanks for the offer on the
the starter only needs
the starter only needs something like 220 cranking amps. so i went to walmart and picked up the lawn mower with 230 ccas. i then went to the home appliance section and threw it on a scale to see if it was worth it. 13 lbs. yah its worth it. it took off more weight than the hood
so ive been running a $20 lawn mower battery for a year now and it weighs as much as a 'race battery' but is 1/4 the cost. the difference between the 1.5 and the 1.6 is really marginal, but you are right about losing your sub 2000rpm power. i never ever, 3V4R |V3V4R drive at that low of an rpm, ever. |
Hey jared, what type of
Hey jared, what type of battery is that? I'd like to find it not at wal-mart, :p
Re: Hey jared, what type of
I would still be temped to get a gell cell, is there reason not to go with a gell cell? |
Here's a thread detailing a
Here's a thread detailing a small battery - https://www.honda-tech.com/zerothread?id=695215
The one there is a Hawker EP-13. It weighs 10.8 lbs vs. the stock 30 lb battery. Cost is about $40 for that one - if you can still find it. I did a breif search and can't find that one anymore. But I did find a similar battery here:https://www.stealth316.com/2-dynabatt.htm But it's like $80. Toecutter: The gearing mods may not be that hard to do - I still have the OE VX transmission but it's in need of some r&r (input shaft bearing needs replacement). I saw the Keeps on Rollin' CX that had many aero modifications - the mpg blows the mind. I do plan on doing a belly pan at some point and I'm gathering materials now. Has anyone done experiments on the rear wheel skirts? I know they are benificial, but I wonder how much and if they depend on other areo mods to be effective. This is a great site! |
Re: Here's a thread detailing a
Sweet thanks - I'll do a
Sweet thanks - I'll do a search. That's an L3 trans though - how much different is the S20? I mean, aside from the hydraulic/cable and mounting issues? I've seen Mista Bone do a hybrid trans using mix-n-match components... |
I talked to bense and if you
I talked to bense and if you feel like not doing the working he'd be game to do whatev with your tranny. He can custom build them or blah blah rebuild or whatev, that's all he does, :p
On the bellypan note: I've heard that there are some of the performance types that have tried this and ran into heat problems associated with the exhaust. Something about boiling gas in the tank? :o I know some of you guys have done the bellypan - have you noticed any problems like the above? |
