Rim painting...
Guess who ****ed up my paint putting my tires on...Anyway, how should I repaint? Totally redo it and take all the paint off or just sand down the ****ed up areas and hit them?
I'm so pissed right now, don't feel like messing with this ****. |
Re: Rim painting...
your not the only one. i put my almost new tires on my new optonal rims and nearly tore the bead in half :( i continued to put the tire on and it holds air and my fat *** in helga so i guess it ok when i do 103 in her :P as for the paint i'd just touch it up. no one will notice from a distance. |
I should've waited and
I should've waited and mounted them tomorrow at the shop during lunch. I guess tomorrow I can do the front suspension or something, :(
soapy water
a little soapy water should help the tires slide onto the rim next time. I hear it also helps to seat the bead cause it allows just a tiny bit of wiggle room before it dries
I didn't mount them, when I
I didn't mount them, when I mount tires I use tire mounting lube spray, :p
that sucks about the rim
that sucks about the rim scraping. you'll be able to fix it up nicely though. just re-do the rim part (i'm assuming that's where they scoured it).
