MID Install
See here: https://crxmpg.com/supermid.html
Could you detail how you get the mechanical part to work in case anyone else needs to do that? (Like me, for instance.) Thanks in advance.
If you have a mechanical VSS it's likely that you also have an electric pulse that goes to your ECU. I'd track down a service manual with ECU wire pinouts to find out which wire it is. |
Got a SuperMID from Yoshi last week and am tackling the install this weekend. I took a peek under the dash of my '92 Civic Si and had a couple of questions that I'm hoping other Civic/SMID users can help with.
How do I get the panel covering the ECU off? How do I identify the injector wires from the ECU? How do I find the VSS? It looks like all my wiring is tightly wrapped in harnesses. Which harness do I break into? How do I identify the VSS wire. The power and ground shouldn't be a problem. Any other tips greatly appreciated. Thanks, Sean |
You don't need to take the cover off the ecu itself, but to get to the ecu there is a cover over it. It's on the passenger side under the dash sort of up on the side by the door.
https://crxmpg.com/obd1pinouts.html Those are ecu pinouts for your ecu so you know which wires are which. |
Thanks Ben. I think I found it :).
https://servercage.com/wordpress/wp-c...0/DSC00352.JPG Now I just have to get the cover off and get at the connectors. |
Good luck with it, :thumbup: for the MID. Alost makes me wish I was still addicted to gas, :p
Got the cover off and unplugged the harness. When I matched it up with the pinout diagram the A1 INJ1 color was brown as in the table but the VSS pin B10 was yellow/blue on the car but orange in the table. Am I okay with that?
Thanks, Sean |
Looks like the VSS is blue and yellow. Check out this picture for help locating the right wire:
https://www.pgmfi.org/twiki/pub/Libra...OBD2to1ab2.jpg The picture is looking at the ECU female plugs, so it can also be looking at the back of the wire harness plugs. |
