ScanGaugeII
Installed the new ScanGaugeII just as I left with the fillup on a trip to PA so it now sits on the steering column and is much easier to reach than the dash - little tricky getting used to the HOME buttom on the lower right instead of center. Good news is that when the engine is off it does go to sleep quickly when Gauges are selected whereas the old model would not shut down properly. The larger characters in the display are much easier to read and the backlight is plenty bright enough on the lowest setting to see in the nighttime and daylight is even easier to read under any lighting condition including bright sun with strong shadows.
TWO THUMBS WAY UP! |
Wow, the original wasn't backlit!?!?
Yeah, unfortunately your car can't get it done with this little device, :(
hehe, luckily i have the supermid, so i don't need the scangauge, :p
ScanGaugeII
It was backlit ok but the daytime viewing was not too great - the new one blows it away.
Well, I'm glad, very glad indeed.
Sgii
Hey just figured out when my MPG jumps to double is when the GPH drops from .2 GPH to .1 GPH not sure what makes that happen but maybe as the engine breaks in more it will burn less fuel at idle.
Just did a 52.3mpg run returning from home - 48.2mpg today Home and back with a stop, engine temp dropped to 137F some highway. |
Ok bad news - the SGII still has problems - found it running and crashed this morning had to unplug it and plug it back in to reset it. Seems I turned off the ignition last night before checking the odometer reading and quickly turned it back on and then off again and it didn't like that at all. Didn't loose the info but it thought it was yesterday and still had mileage and gas used from yesterday on the current display.
