New Website: Honda-Search.com
I've been working for the past month or so on a new website that I'm hoping will help pay for the server here. It is a Honda-centered site, but it contains valuable technical information that all people might be able to use.
www.Honda-Search.com is a search engine that searches a number of popular honda internet forums. If you need to know how to replace a fuel filter, oil filter, head gasket, or even and entire engine you should skip google and go straight for Honda-Search. Why? Well, you'll filter out all of the info for other makes and models and find information on exactly what you want. I've also made Honda-Search only search certain the technical forums and not search the "general discussion" forums and other non-sense information that you don't need. On top of this, signatures are not searched, which makes this a much better alternative to Google or Yahoo, which will sometimes give you a hit on something in someone's signature. I'm happy with what has been accomplished so far. The site isn't done yet and I still have a lot of things to add to it. I would however like to announce it in hopes that 1) You use it, and 2) you tell others about it. Feel free to post links to Honda-Search on other websites, or even post links directly to the results. Just thought I'd share a new site in the same network as GasSavers. |
Can I choose forums to search, such as only sale forums?
Darn, no luck for my d15z1 swap.
No luck on VX for sale. How would you suggest I search for better results?
Dan, you'll never find a stock vx for sale on a honda site. They're just too slow for people not to do something to them, :p
I suggest that normal people are the only hope for that. |
yea ben is right. autotrader is your friend for stock vehicles.
good job on the search site matt! |
That's an interesting site Matt, and looks like it can be a valuable tool.
But something that I don't see: Links to Honda Tech, or SOHCHonda. Not that there is not some good information on those other sites, but H-T is a MASSIVE website. If it's been asked about a Honda, it's most likely on there. You may have to sift through several "junk" posts to get to some "real" good information, but it's a great resource. Also, and I may be a bit biased, but SOHCHonda has basically the opposite - it's a much "smaller" site (read: volume), but has much "better" information. Not a lot of "junk" posting, and we try to keep it that way. Hopefully you'll see this as it was meant to be - constructive. I think what you've done is great and will be an awesome tool. |
Matt told me something once about h-t's urls needing figuring outing, mehbe he'll add sohchonda now though, :p
That being said, right now I'm crawling 5 sites using vbulletin. They were the easiest to get started with. I'm going to add honda-tech sometime soon, but their URLs are different than the rest. Vbulletin uses a cool archive format (www.gassavers.org/archive/index.php/ is an example). It's all plain text and easy to navigate. Honda-Tech has a "printable view" of pages, but it's a little bit more difficult to crawl. I'm going to have to write a custom crawler to grab all of the URLs from honda-tech and then crawl them. It'll be easy enough to do, just a little time consuming. Soon I'll also make it possible to put a search box on different forums that enable you to search using honda-search. |
