Busted Oil Cap
My wife's Stratus has one of those "racheting" oil caps on the valve cover. You know, basically like a gas cap - tighten until it clicks.
Unfortunately it seems like it's busted - it just clicks in both directions now. I wondered at first if it was a "child-proof" feature :p so I kept pushing on it and turning it, but it won't budge. What's the solution? Crack it with a chisel? I'm slightly worried about plastic falling into the crankcase if I do that. |
I'd cut the edge with a hacksaw so any debris would fall outside until it was too loose to stay on.
I suppose another solution would just be to pull the valve cover off...
That would be the clever thing, :(
What about just drilling it with a very small drill and put a coat hanger in, to lock the top and bottom together, so it will turn?
I would still worry about plastic debris if I drilled or hacksawed it. I think I will remove the valve cover first and then I can do whatever I feel like to get the cap off.
Don't worry about it. I've been thinking about it off and on for two days! :D |
I ought to have thought of it, since I've been playing with valve covers for days.
Bah, you would have thought of it sooner than I did. :cool:
Nope, I would've just smashed the threaded portion off the outside.
