(Note: decided to move the Metro related babble into this new thread, rather than continue to hijack Dan's Project KBA, KMA thread.)
Dan wrote: Quote:
I haven't seen any information about lean burn at teamswift or in my factory service manual. I think the article you quoted is wrong there. |
I've seen several comparisons of the XFi drivetrain design vs. regular 3-cyl Metros, and have never seen lean-burn on the list. I think if it did have lean-burn, its numbers would be even higher than they are. Would lean-burn require a 5-wire o2 sensor, for example? Both the XFi and non-XFi share the identical part there, and it's a 1-wire affair (for a '94 Metro, according to the rockauto.com catalogue). I've raised the question at teamswift - maybe someone can answer definitively. --- PS - anxiously watching this thread to hear about Dan's trip... |
I think the ECU may have looked for the lean-burn signal from the O2 sensor rather than lambda, but I don't know. I actually remember reading that the NOx emissions were higher on the XFi due to the lean burn, but I'll have to find my source again. |
Heard back from a teamswift member, who intelligently pointed out that the sentence in the linked article doesn't explicitly say that the Metro has lean burn. Read it again...
Bank robbers often drive getaway cars, and Dan is driving his new VX from Chicago today. |
I knew there was something odd about dan...
Anyway, why doesn't someone just hook a DMM up to their car and go for a little ride? |
I think I've already done the DMM lean burn test equivalent for my car when I did the speed vs. mpg chart. If there were a lean burn mode, I would think it would show up differently than the essentially smooth line I got. From the reading I've done of Insight drivers, the slip in & out of lean burn mode is blatantly obvious on the instant fuel consumption display. However, if it's only an XFi feature, I can't test that. But... the owner of the XFi who pointed out the sentence structure issue was also unable to find any reference to lean burn in his service manual. |
I have no clue where I got the idea it was. I actually wrote it in my log way back in September/October. Maybe I found a reference to NOx emissions and assumed the XFi was lean burn...:confused:
I'll just say it was due to my brain-cloud. :p |
