The lower the rpm and the higher the gear the less fuel wasted. Get into 5th asap. Even with civic I doubt I'll get the scangauge. I'd rather waste $180 on some LRR tires.
NOTE FROM BEN: I moved this from another thread and made the title, this discussion wasn't prompted by compaq but was clogging another thread, though it's important so it has its own now. |
Text moved back to the proper thread...
I believe jangeo and darin have done some serious testing on the hill matter and both decided that the highest gear still wins. I feel the same way based on what I've noticed during the small amount of hill driving I've done. Even with little torque and being at 1200 rpms I've not had to downshift, and I can scoot along just fine at 1000 rpms. Hell, at 30 mph I'd practically have to be in 2nd gear to gear to get up to 2500 rpms, :p, and then my throttle is open more, anyway. |
The only reason I'm not running high psi in my civic is because the rear tires need replacing. Once they are replaced I will bump up the psi. I also know about bump starting, different coasting methods, aero mods and etc. Once I get the clutch thing right then I'll start to focus on fuel economy. There are plenty of Honda owners here who report their findings, I already know what improves fuel economy and what doesn't. Getting better fuel economy is reading fuel economy websites and experimenting with your own car. |
Knowing the theory is only half of it. Feedback is the only thing that will tell you if you are applying it properly. |
With this manual now I don't really need a scangauge because most of the time the highest gear and the lowest rpm will give me the best mpg. The only use for it would be to see how much of a difference the mods would be. Or to see which version of the aero mod works better than the other. Metro, Dan, nor Bajoos haven't even does this. So the only reason to buy it is if you hit the max of your car and to see if you modify your aero mods if it improves fuel economy. |
See, but you're wrong.
I don't not what you're saying about dan, darin, and basjoos. Basjoos is the only one getting great mileage without one. Zpiloto took a car almost as sucky as yours and gets 40mpg with it, because he has a scangauge, :p I have more data in a two weeks of driving from my mid than you will in two years with tank reciepts, and I still think I'm missing a lot that can be done. One day dart vader will throw you down a whole and you'll realize that your overconfidence did indeed lead to your downfall. |
He also screwed with his transmission, I didn't. Picking up another 3-5mpg was too much risk for the transmission. |
