IN terms of ease of installation, availablity, etc., I'd say that a CX/VX transmission is the way to go. |
I should've also noted in my post that you'll want a 92-95 cx transmission, :p
CRXHFFTW |
Thanks guys. Just wondering. Also, since I will be going from the OBDII '97 HX tranny to the 92-95 OBDI CX/VX tranny (assuming I find one), will i run into any problems with the Vehicle Speed Sensor (VSS) or anything like that...
The VSS might be different, I'd do a part number search, but I'm fairly confident that even if the shape of it is different the old one will fit in the new hole or if you have a cx/vx one it'll plug into the old harness.
Thanks--Good to know.
In my case, I used the VSS sensor that came with my CX tranny. It actually improved the accuracy of my speedo a bit. I went from about 3% too high to about 2% too low. I'd keep the one that is in the tranny if it is still there.
-- Scott |
Okay, I found a transmission for $150 out of a '92 4-door (don't know the model), the seller gave the ID number as S20-1185791. Does this tell anything about the transmission or is it merely a serial number?.... Also cx and vx were only 2 doors right?
CX and VX were only two door hatches, that tranny is prolly no good.
**edit** i found the stamp near the fill plug on my tranny, it indeed says A000, so i guess i have the right trans thanks NICK |
Hey guys, thanks for the info. I finally got a CX tranny from ebay w/ 110k miles for $41. It didn't come with the VSS or clutch slave cylinder.... I was hoping I could use my '97 VSS and clutch slave cylinder in the '95 CX tranny. Will it work?
