Back to Council/Attorney
Well, if the city council and City Attorney has no problem with, by all means, toot your own horn.
-RSH v2.0 |
Considering you can't here my music inside my house when the car is in the garage, I do not consider the volume to be an issue. My system has very little bass and as loud as I can stand to play it has never been loud enough to bother anyone else.
Not that any of that matters, but whatever. |
Try LR
RH77 |
Just bought one but am working on paying for it without having to enter my PayPal password into the vendors checkout system. I was redirected from eBay/PayPal during the paying process. I'll let you know how it goes tonight.
This memory makes me wonder if I could tap into my rear defroster. Why couldn't it serve as an antenna too? However, when it is on I have a hunch that it wouldn't work because the heating coil/electricity/whatever would probably be generating interference. CarloSW2 |
-- Scott |
CarloSW2 |
I finally received the internal antenna from the eBay seller mentioned previously. They were a bit slow but delivered the advertised product eventually. I had to run the thick wire along the underside of the dash and secure the grounding strap to a screw under the glove box. Then I snaked the thin wire from the provided spool behind the right side pillar molding and across the top of the windshield. I got decent reception but nothing spectacular. Since we live in a really low spot I didn't expect much reception. The real test will be when I get out on the highway.
https://servercage.com/wordpress/wp-c...0/DSC00348.JPG https://servercage.com/wordpress/wp-c...0/DSC00353.JPG |
Anyway, the reception out on the open road this morning was fair at best. Better than nothing but not very good. When I auto scanned I got 4-5 stations. As I remember it I used to get 10-12 when the external antenna was in use. I'll try messing around a bit with the position of the wire but I don't hold out much hope of getting significantly better reception. |
