LRR Suggestions
I'm looking to replace the tires on my '92 Civic Si and wanted to get the best tires for FE. The rims are 14" and from an Accord. I think they are 5.5" wide. Based on my reading I'm looking at the following options.
Bridgestone Potenza RE92 165/65SR14 Bridgestone B381 185/70SR14 Dunlop SP20 FE 185/70SR14 Any suggestions greatly appreciated. Sean |
I have the Potenza's on my Yaris, not a bad tire from my point of view, but I have read horrible reviews. I put 44psi in them and the ride is harder than stock but I expected that.
Early US Prius came with the Potenza, Canadian prius came with the Dunlop SP10 |
Krousdb put the Honda Insight tires on his 14" rims. I think it would be best to figure out which tires they put on the Insight and get them on your car.
I imagine they are very similar. Perhaps a call to the manufacturer of the tires is in order. |
Great idea. Just got off the phone with Bridgestone tech. The person I talked to did not have much information and did not indicate that there was anyone else who might have more info. They did indicate that the OEM tires would give the best mileage due to CAFE requirements. They also said that OEM tires have a slightly softer compound which gives better fuel efficiency and better handling. This did not entirely make sense but just passing along what Bridgestone had to say. I'm going to try a few more and see if I can get better info.
Sean |
Not much better at Dunlop/Goodyear and Michelin. The Dunlop rep had no info at all and even asked a senior rep who also had no info. No reference, nada.
The michelin rep indicated that they had the MX line of tires that was somewhat designed to give Lrr by incorporating silica in the tread compound. https://www.michelinman.com/overview/...4_plus/95.html They don't have any data or studies to back this up though and there is only one tire in the 14" rim size and none in 13". This is definitely not an area where tire manufacturers are doing a whole lot. |
*sigh* at tire manufacturers. Perhaps you could call honda and find someone that knows about the tire selections process (since all these tires are on hondas)
