Iono WTF that pictue is but it's wrong, :p I can take a picture of a transmission in my basement for you.
Anyway, none of the auto tranny mounts work, they're all slightly different. You can get the manual ones fairly cheaply though. |
where should i look for the transmission mounts?
Junkyard/h-t. You can get them new from honda if you pay out the nose. Check with the person you buy the tranny from. If they went b/h/k series they'll have them for you.
Here's where I got everything I needed for my conversion:
*HF transmission - a friend's back yard (try Honda-Tech or a local honda board...I have ImportAtlanta.com) *Rebuild parts for HF tranny - www.hondaautomotiveparts.com *Pedals - Junkyard *Flywheel - I had one, try Honda-Tech or ImportAtlanta equivalent *Clutch - eBay (less than $100) *Shift Linkage - Junkyard *ECU - Honda-Tech *Mounts - Honda-Tech *Clutch Cable - Autozone |
Would it be easier to conver to mpfi and obd2 if i had a harness from a mpfi crx? Or is it the same regardless?
It's best to stick with your existing harness. Not only is it cheaper, but the MPFI wiring only takes like 30 minutes if you just follow the directions and know how to do a little wiring. |
