Removing Muffler (good or bad)
I heard bunger say that the muffler doen't help fuel economy at all. I was just wondering what you guys think?
btw I can deal with the with the noise. original post by bunger: Quote:
5-colour Tempo
So why didn't you spring for the Topaz? Better re-sale. RH77 |
It's the Internet
Come to think, it would be harder to find 'Paz parts as there were fewer of them. It's just that whole Ford/Mercury re-badging that makes no sense. They still do it today with the Escape/Mariner, Fusion/Milan, Crown Vic/Grand Marquis, Explorer/MKX, Expedition/Navigator, etc. Now Pontiac is coming out with a G5, which is essentially a Cobalt. Make NEW cars already people! New rule: no more brand sharing. :cool: RH77 |
Lol
Initials and Year |
But some people are fooled by badge engineering, so...why not do it.
A couple of excess noise fines and a forced reinspection of your muff-less car will negate any FE money savings.
My CRX came with a **** muffler so I ripped it off and drove around with out one for a a month or 2. When I finally put the new one on my MPG went up.
Muffler fuel economy
1) Reducing the exhaust backpressure will allow more air to be sucked throught the cylinders and intake. The ECU will control the air/fuel ratio at stoichiometric, so the fuel rate also goes up. Great for power, but not for economy. 2) Then, because more air and fuel is being burned, the ECU must tighten the throttle. So by removing the exhaust restriction, a worse restriction is added to the intake (at the throttle body). 3) Exhaust systems are "tuned" for a given rpm. Changing the exhaust geometry changes the most efficient operating point of the engine. Reducing exhaust restrictions usually raises the best efficiency RPM, again, good for power, but not good for economy. Save your neighbors' ears. Keep your stock muffler. |
I'm not suggesting everyone go remove their mufflers, but there are things that could be done to the exhaust system to improve FE. It would be pretty easy for me to add a restrictor to my exhaust system, I wouldn't mind rolling around with it for a week or so to see what the results are, maybe I'll have to eat some of my words. =) |
My Ford automatic idles at the same rpm regardless of what N or D, and so does an 07 Camry that I just rented Monday. This can't happen unless the ECU is controlling the throttle to some extent. Anybody shed light on how much "drive by wire" control is in newer cars? |
