I don't run EGR on this particular engine. For my uses, it's completely pointless.
And I agree with them completely, because unfortunately for you it's not an estimate. It's what happens. Get your *** on a dyno, or devise an accurate way to show time to acceleration & find out for yourself. It takes at most about a full year to turn an EGR equipped intake black from the plates to the valves when the valve is operating properly. Clean yours, leave the EGR intact. Come back to the post & tell me I'm right next August. And here's the problem with your bull**** about how long anyone has been a member of any forum... How long someone has been someplace has no ****ing bearing on what they know. I'm a professional technician by trade. You're obviously not, or you'd have know better. So your head in my ***. Take care of that. :rolleyes: And guy... It doesn't take a rocket scientist to see that the more you leave that valve open, the faster its going to cake up. |
Hey, guess what, if you make the claims, present the evidence. Do three dyno runs with your dirty EGR/intake, clean the intake/remove it, then do three more. Make sure to video tape it, and post everything here. If you're a professional technician by trade, you shouldn't have any trouble doing this.
At the same time, I'm wondering why you're worried about even a 5hp loss in what's essentially a family car. Yeah... gotta get every bit we can out of a platform that wasn't meant, and is hard pressed to be, relatively quick in the first place. |
RH77 |
I wanted to make a couple of comments, but I've lost my appetite.:confused: |
Then, why don't I understand it? Or you? Or this explanation? |
High EGR "rates"... first, let's understand what is meant by EGR. Exhaust Gas Recirculation is nothing more than the dilution of the intake charge (A/F ratio) by spent exhaust gas. This gas may be hotter than the air temp., but it won't burn again! By not burning, it absorbs the heat of what does burn...the gasoline mixed in with the air. No burn = a reduction in temp. of what does burn. |
