Cardboard box + duct tape =
Grill block! :D
had the box to use for a rad block and still had plenty left over so an hour and a half later i have a crude grill block on "Lil Silver" now. there still two small opening by the turn signals in middle and i'm hoping that maybe they will be enough. this is just a crude temp thingy to see if it'll help with getting up to temp and possibly run a lil warmer. I only have a 5.1 mile drive to work and it takes almost 2 miles till fully warm (180 range) didn't have anything to use to fasten it so i folded some duct tape over onto itself and made my own ties and tied it off to the grill. gonna carry flashlight, and box cutter in case i have to do some roadside mods. also i found i can turn ac on then off and fan will keep running. between that and the heater i will be fine. The mods have started! :eek: |
sweet...i cant wait to getting around to my 'necessary' modifications of aerodynamics
though i think i will skip the use of cardboard... :p |
It's a good time to put a grill block in because colder ait is on the way (Oh, I just saw you are from flordia. nevermind). It still helps in warm weather.
cardboard rocks, it took three rainy days to take my upper grille block down, and i still have the original bottom part! Whoo!
best of all its FREE |
got caught behind some cars moving slow from a redlight and had to slow down whereas i usualy can make the light without slowing much. on way home seemed to warmup a bit quicker in slow speed driving (getting up to speed) and when i did get stopped and shut down on restart temp was a bit higher, but i'm gonna give it about a week or so of driving. might end up having to use a partial rad block or underbelly pan between the bottom of the rad and the engine to get the full benefit. |
Most of my driving is a short 5 mile trip to and from work. car temp would be mid to low 180's and would climb a lil when stopped or slow moving.
today i went to the mall and got into some stop and go traffic and temp was nearly 220! that was a lil much so I turned heater on to get it down and found once moving about 30-35 mph was ok. the trip was about 10-15 miles. I noticed that the instant mileage reading was showing a bit higher with the hotter temps and even the ait was showing higher too. temps here today are right around 70. air inlet temp was right around 90 those 5 mile work trips aren't getting the engine temp up, but not much else i can do. maybe block of the rad but then what about when i take longer trips?? |
Check out the grill block that I just picked up! :D
https://www.fuelly.com/attachments/fo...56b499fa74.jpg |
i'm gonna have to climb under neath and see if i can find the core plugs or a place to put on against the block 90CivicStandard: how much you boosting?? |
