HAI ver. 1.02
I worked on improving the HAI today. I have no testing yet. I'll get some running temp results later today. Here are the pics. The material is aluminum vinyl siding coil. Its coated with a mylar armor coat on the finished side. Hope it doesn't go up in flames.
https://www.fuelly.com/attachments/fo...c8de13bd4a.jpg https://www.fuelly.com/attachments/fo...da7e859346.jpg I had 3 months running the old setup and hope this improves my winter mileage. I seriously doubt I could run this in temps above 70 but will see. |
:thumbup: I like it! Way to squeeze into the area by the ac.
Nice Setup
I predict you'll exceed your goal of 70F for your setup. With the trapped heat in the box, I can see 120+ possible.
edit: after re-reading, I see you mean running it in ambient temps of 70F. Still, nice setup! RH77 |
Results
60mph steady cruise 50 degrees ambient. 130-135 degrees EOC'ing 4 miles last four miles of 15 mile trip 40mph max 39 degrees ambient 110 degrees All results are taken with a car stopped engine on. Boy do I need an SG |
I think Ill rig something up for this winter; its not even halloween and its 35 degrees and has rained for like 18 out of the last 20 days :thumbdown: Wisconsi for the lose. I thought the HAI was "busted" according to the stickied thread?
My car is an auto. I know my car is more likely to go into final gear at low rpms with hot air. The car seems to stay in lower gears longer with colder air.
I'd be worried about that vinyl :O. I've seen my exhaust manifold glow red hot before. I like your idea though, one of hte big 3 used this setup way back when on a "highway" car or something like that, they got extremely hot intake air, i'm not sure exactly why they wanted it, but they got it. I was thinking something like this for a heater on my car, suck air from around the exhaust manifolds, instant 1,000 heater, thats' gottta work better then 200 degree water. Sure if i get a leak I'd quickly die from carbon monoxide poisoning, but hey, thats' a chance i'm willing to take for a nice warm car haha.
red91sit -
https://www.saturnfans.com/forums/showthread.php?t=71674 Quote:
