DA brakes with HF tranny
What axles can I use, Im tired of the crappy HF brakes, Im upgrading to DA drilled and slotted rotors Im getting from a friend. I was wondering which axles will work with those brakes and HF tranny?
Did you upgrade just calipers and rotors or did you swap the entire spindles onto your car? I'm assuming your car is an 88-91 Civic, right? Which engine do you have? If you are still using a D-series engine in an ED/EF chassis, I THINK you can use regular (non-HF/non-STD) axles from an LX, DX, EX, or Si from the same generation Civic.
I have a HF tranny and use the axles from my civic LX with my DX brakes. in other words, I think DaX is right.
I just didnt know if they were different on the tranny side too |
