Ya, I can tell you in a VW diesel idling does nothing. My wagon consumes .25L or .05gal / hours once warm. So there isn't enough heat to keep it warm. You have to drive it to make heat, no point in idling; it actually will cool the engine faster since it is sucking a lot of cold air through it.
Here in Wisconsin it is illegal to leave a car idling without a person in it. Which really struck me as odd since they can sell those remote start units. Wouldn't you technically have to break the law to even use them? When it is really cold, like below 0F or -17C I let the car idle until the louder knocking stops, about 5-10 seconds before driving slowly away. I do drive slowly until I get some movement on the thermometer. |
You should have taken the keys and thrown them out the window a few miles down the road! lol
No really, like already stated, these types of people don't care about anything but themselves. People like that really bug me. I can't stand wasteful people. |
Engine-Off Coast
RH77 |
Long idle, in cold, to allow proper warm up is OK and is beneficial in the long term, but you are right on the letting things sit once warm, why bother?
Many years ago, two friends did find a warm running car when returning home from a night of drinking. Figured why not, and took it home....then a voice comes up (radio) and they notice it is an unmakred police car. They quicly bailed out of it....but one did leave a warm and wet surprise in it.....and a detective wondering where is car went. Also, in Athens Ohio around 1990, there were a rash of pizza men that would leave their cars running and run to the door with the pizza. The pranksters (that called the guy) would jump out of the bushes and then drive the cars to the intermural football fields of south green and "launch" them in the Hocking River. Several reports of this in the Athens News at that time. |
I would agree
Fuel maps support the theory. RH77 |
You can buy a lot of fuel for the cost of a motor. |
Actually, the average car at idle takes around 1/2 gallon per hour of fuel, so even at 10 minutes to warm up, you are not approaching anything that would be a large negative impact on fuel and the benefits of a warm car for comfort are added also.
Interesting on cold temps in that one link, the coldest I have ever started a car and drove around (without problems I may add) was about -32F. The car? Volvo 122S. Yes, with SUs.
Not sure on the wear comment in the thread there.....have seen the wear and then there is in fact a negative FE from running a car not warmed up, drive one around with a bad thermostat for a while and see what happens even in summer. Agreed on the idling all day, even the railroads in the US are getting away from it now. |
More links...
Taken from https://oee.nrcan.gc.ca/transportatio...nce.cfm?attr=8 "An engine can burn up to 50 % more fuel for a short trip in the winter than for the same trip in the summer. Fuel combustion is also much less efficient in a cold engine, and the air-fuel mixture is richer (i.e., there is more fuel and less air). The combined effect is a sharp increase in pollutants. To make matters worse, the catalytic converter doesn't work when it is cold. Until the converter warms up, all the engine's emissions pass through the exhaust untreated. One answer to this cold-engine dilemma is to use a block heater to warm the coolant, which in turn warms the engine block and lubricants. The engine will start more easily and reach its peak operating temperature faster. In temperatures below 0?C, block heaters can improve overall fuel economy by 10 % or more. Use an automatic timer to switch on the block heater two hours before you plan to drive the vehicle. This is all the time needed to warm the engine. Warm Up by Driving Once a vehicle is running, the best way to warm it up is to drive it. With computer-controlled, fuel-injected engines, you need no more than 30 seconds of idling on winter days before driving away. Anything more simply wastes fuel and increases emissions. Besides, more than the engine needs to be warmed up. So do the wheel bearings, steering, suspension, transmission and tires, and that can happen only when the vehicle is moving. For a typical vehicle, it takes at least five kilometres of driving to warm up these components. Although it is important to drive away as soon as possible after a cold start (but not before the windows are defrosted!), you should avoid high speeds and rapid acceleration for the first five kilometres or so. The goal is to bring the whole vehicle up to peak operating temperature as quickly as possible while maximizing fuel economy. To prevent your car windows from fogging up, open a window as soon as you enter the vehicle. Clear snow from the air intake on top of the hood. Otherwise, the defroster will draw moisture into the system and fog the windshield." This can be cited over and over if necessary... RH77 |
RH77
Very good article there from the Canadians. Very true on the points of the suspension. You and I can relate especially to Citroens in cold mornings firsthand, I have not experienced that in many many years myself, but can remember "stiff" times. Then, there are other cars that not all functions will work until warm including the older ACC systems in Mercedes and top gear on Toyota automatics from the 1980s on. But, once again, and I am surprised as the article does not talk about the negatives of engine wear. And ditto too on cool down, especially diesels and turbos. Don't cut the engine when not at idle and give it a chance to "cool". |
