1993 Civic CX transmission??
I found one of these in a yard near me. Is this transmission worth taking? I have the HF with the shorter gears (49 state, I guess....not the taller ones that I'd hoped for). Anyway, what's the gear ratio for this CX? I'm wondering if it would be better for me.
Otherwise, should I rescue this tranny before they crush the car? Anyone need it? (Just not sure if it would be worth it to you after shipping). -Brian in Virginia |
I wasn't aware that the HF came in different gear ratios. I'd recheck that just to be sure.
The CX transmission is only good if you have a 92-95 Civic. It will NOT fit in earlier civics at all.... well, unless you want to hack and weld it on there, and then convert to a hydrolic clutch. |
Sure. There was a 49 state HF and "the other" model. The other model (California?) was the one that gets better mileage, due to a taller 5th gear. My '91 was that car. My (current) '89 is the former. This is why if you check the EPA estimates, you'll see 2 listings for the HF model (probably all between '88-'91. The worst part about it is finding out how to decipher which trans is which when it comes down to differentiating between HF's.
Can't the CX transmission be used in a later civic like a '96-'00 civic? I know I am looking for one for my HX but I'm in Tulsa, OK.
you can easily use it on 92-00 D-series civics, and you can make it work on 88-91 D-series civics if you do a cable-to-hydrolic clutch changeover... Hasport sells a kit. I don't think there is any hacking or welding involved.
For the money required to it to work (cable to hydrolic kit AND the mount kit) you would be much better off just trying to find a California CRX HF transmission. |
