Metro, that sounds like no problem. I just changed out the thermostat, and this doesn't sound any harder from how you describe it. Now i need to find out where mine is, and what model/size heater plug i will need. thanks!
Combination of things: efficiency/effectiveness (heating the coolant&engine directly, vs. wasting heat to surrounding air as with bolt-on/magnetic types or inline hose heaters); price (cheap); simplicity (proven OEM style).
Though I'd change my tune if I knew more about the high-wattage (1000+ ?) type Brock uses in his TDI (recirculating inline in the heater-hose). I had read a couple of accounts of them failing though. Also, I don't have enough room under my hood for one of those. |
i have a 7th generation honda civic engine block heater, anyone wants its for dibs for cheap.
DAX, that hex bolt just unscrews and the frost plug comes out with it? It isn't a press fit plug that you need to pry out?
