skewbe |
01-30-2007 06:57 PM |
Originally Posted by Coyote X
(Post 39131)
I seem to have slightly better mileage at 5 degrees cam advance on mine but I think it is mainly based on type of driving and speed.
It may be because you have an xfi also. suprf1y was pushing the 10 degree ones for my car, so I went for it. But I read a bunch of stuff you wrote about your experiment on teamswift also, and it was inspiring. Props. Nice to have the option to reuse a perfectly good cam gear, too easy.
(Post 39131)
You need a timing light though to see what you really ended up with.
I did find my timing light last night, but couldn't bring myself to waste gas on a tune-up warm up, so waited till this afternoon to fiddle with it. I had the good sense to made a mark on the rotor at tdcc before I started and the original distributor position was obvious, the ungrimed area where the washer used to be. It looks like I wound up at 12 degrees +- 2 degrees. I discovered there is a lot of slop in the rotor, I thought it had a busted mechanical advance till this afternoon :eek: so I kinda forgot about the rotor mark. Good enough for now.
(Post 39131)
I tried my car at ~ 3,5,10,15,18... Takes like 30 seconds to adjust it that way.
I think I just figured this out. I was worried about getting to the tensioner bolts down low. Do you just leave the tensioner locked where it is and bolt the gear back into the pre-existing belt tension? That would be quick enough to do.
