diamondlarry |
02-01-2007 04:31 PM |
Originally Posted by lovemysan
(Post 39409)
Crud! Your worthless!;)
well not really. You did send me instructions about the kill switch. Well anyways I think your supposed to use some type of shim stock and the bolt washer keep it from sliding out of the cam gear. I need to find that stuff.
Do you have anyidea how long it would take to get the cam gear off my sohc? I'm a competent mechanic and have done a cam swap on a my nissan.
Now you see why I was assinged the non-critical jobs.:p Anyway, the hardest part will probably be getting everything out of the way to get the front cover off; power-steering, A/C, top enginge mount, etc. You will also make it easier on yourself if you jack up the car and take off the right front wheel and the inner fenderwell. Then you'll have to get all of the bolts out of the cover. It seems like there were some small bolts/screws down by the oil pan that could easily be missed. Then you have to pry up a little on the front cover then out. Using air tools like we did, you could probably have the gear exposed in an hour but, the first time you do it, plan on longer.:p Also, make sure there are no women or small children around in case of a slip of a naughty word or two.:D I did quite well on that though.:)
