Good thought to check on the "cold" vs "hot" states. And you're absolutely right - there's nothing scientific about this. Collecting this info is only really good for "things that make you go hmmmm....". |
MetroMPG -
If you want an MPG leader to increase your fleet MPG, just "design to the test", aka "leave no car behind" aka "leave no Hummer behind". CarloSW2 |
zpiloto -
Wah-Wah-WAhhhhhhhhhhhh (Gameshow "you lose" music) CarloSW2 |
= 4.2% below EPA on average
Their average: 42.7125 mpg (US) = 7.2% below EPA (46) If I had posted the mileage numbers for the '95 metro I owned last fall I could have pulled the average down a bit more. ;) Obviously there was something wrong with it. After pricing a 4 wire oxygen sensor and then a dimmer switch I really lost my motivation with that car. I did not need the dimmer switch. The light wire had burned up at the main junction block for the whole car. It is only anecdotal but it sure felt like a draggy car to me. However this 2001 Saturn SL I am driving now is pretty amazing. I have never beaten the highway EPA numbers so easy in my life before and it is rated 40 mpg. The scangauge is not fully calibrated yet but is close. It shows a bit over 40 mph most of the time at 65 mph. This car is still completely stock except for 60 psi in the tires. I will be fueling again in a few days and then will have a real number. My scanguage completely reset in the middle of this tank though. Does that happen often? I think I hit two buttons at once with the engine off. Ernie |
Longevity also affects the enviromental impact as well as the economics. |
