Toyota Tundra Lover
I have a 2003 Green Metallic Toyota Tundra Stepside a real Beauty and have bought but not installed yet a K&N cold air intake, a Throttle body spacer and Headers. I am doing this for 2 reasons one is to increase Power and by increasing power I will get better Gas Mileage by driving in a very easy manner. No Lead footing. I will report on my results.
Cowboyjack |
Welcome to the board cowboyjack :) Good to see another guy with a truck :D
Hey guys correct me if im wrong but im almost conpletly sure that a cold air intake would worsen fe. Reason being that you can fit more cold air and gas in the cylinder which gives you more power but less fe.
Pretty much, and warming the air may help up to the point where the engine pulls timing. I think a TB spacer is a great idea since it'd be equivalent to increasing intake plenum length, which helps out with low end torque, and could shift the peak BSFC regions lower in the power band. Headers are really YMMV. They may help, or they may hurt, and in this case, I'd stay away from them since a mod for low end power is already being made. Unless of course someone has a before/after dyno that shows a definite increase in low end torque from the headers.
TB Spacing
RH77 |
I have an '04 Tundra DC. Do you have an accurate baseline of your mileage as stock? I am curious to see your results of your mods singly and as a whole. Good luck. Keep us posted. :thumbup: |
omgwtfbyobbq -
Increase MPG: The Factors Affecting Fuel Efficiency (in a Jeep Wrangler) https://www.omninerd.com/2006/07/16/articles/57 cowboyjack999 and Red in particular may find this page really useful. CarloSW2 |
I know VnutZ from another forum (the guy who wrote that article.) It took him about a month to piece all that together when he was bored in the summer. It boiled down two things:
1) the ECU on the Jeep is too dumb (Speed Density system) to react to any changes in intake systems which has been proven from other jeepers via the over all ineffectiveness of all CAI mods. 2)The design of the ARB snorkel is does not favor easy flow. It is basically a large blow molded air tube bolted to the front fender, then fed to the stock air box using a length of accordion hose. As a result, there is little improvement over the stock system. The end result was to stop figuring your average MPG and you'll be a happy jeeper ;) TB spacers are hotly debated as some claim that they have run them and are useless, others claim a noticeable gain. Headers are in much of the same boat as the exhaust manifold is fairly free flowing from the factory. The primary restriction on the exhaust side of things are the head itself. Due to emissions, the exhaust ports are too small to promote good flow. The only I/E mod which has some confirmation of efficiency improvement is the replacement of the muffler. For the Tundra, I think Toyo uses MAF for all their engine management, so long as you kept your foot out of it you should see some gains opening up the intake. IMO I'd learn all that there is about your engine so you can get the best idea of how something could improve its efficiency. Cowboyjack do you have the V8 or the 6? |
Toyota Tundra Lover
I really appreciate your replys. I have a V8 in the Tundra and my baseline MPG is 16.2. As I install each of my upgrades I will let you know exactly what it does for me. Thanks to you all.
